Baxi Combi 130 HE - DHW flow problems
cdg
2 Mar 2006
Bath
Just moved into a place with a 4 yo (ish) Baxi 130 HE. It seems ok on the CH and the DHW for the shower also seems ok (given a bit of patience) but being able to get a sink full of hot water for washing up or a bath is virtually impossible.
Throttling the taps back seems to get the water hot enough for a shave but it's no joy for the bath as the demand cuts off and goes cold.
Any ideas?
The DHW temp is set to 55c (max) and the water coming into the property must be fairly bl00dy cold at the moment (around 4c maybe).
Could be any amount of things!
Plate heat exchanger needs checking for restrictions/blockage first
then....
If there's nothing easier than that to try first I'll get HeatTeam out then.
There's a combimate fitted (but it seems to be to the house main rather than the boiler specifically) but I don't know how old it is.
The boiler pressure when cold is just above 1 but was very low after we moved in. The missus reckons it was easier getting the hot water prior to me bleeding the radiators which had patently never been done.
Would Heateam descale/replace heat exchangers in the fixed price though?
Not an expensive job anyway - watch the cost.
In the London area we would charge about £136 inclusive in case that helps you but in your area it should be considerably less as you dont have London traffic and parking problems to contend with.
Tony
Is that working on the premise of replacing or cleaning/repairing the HE Agile? Guess that doesn't include a replacement combimate either or does it? Ta
