I had a new Baxi Duo Tec Combi Boiler fitted in September 2008, it works fine but needs frequent top up's of water, is this normal or should I call a plumber, the company that fitted it has disappeared!
Thanks for the reply, I've been topping it up to about 2, and it needs filling every week, I have noticed that there is a lot of condensation coming out of the flue on the outside of the house which causes a small puddle of water to form beneath it on the ground, the boiler and flue is situated on the first floor and the old boiler did not do this, any ideas?
