I have the above boiler and want to make it as efficient as I can - the house seems to leak heat like a sieve, despite my best efforts at insulation in the loft. Houses round here are solid wall, many have had green deal external insulation applied but I won't be doing that . . .
I have looked into a number of options for the boiler.
Firstly, weather sensors - can this boiler be fitted with one? And if so, what does it actually do on this boiler? Will it save me £££s?
Second, I like the look of Baxi's own programmable wireless thermostat, BUT the price seems a bit low, does it actually include the receiver? If so, does this replace the clock on the boiler and fill the hole left? Or should I just plump for the honeywell CMT927 (which I also like the look of). Is the Baxi one any good?
The current clock on the boiler is TERRIBLE (its the digital one, you have to press the buttons very hard and it is impossible to set the program without inadvertently turning the heating on or off!).
What temperature should the radiator water be at? If I use the programmable stat, and dont bother with the TRVs, do I need to balance the system to ensure even heating? It has never been balanced!
An in-depth explanation would be appreciated.
Thanks awfully!
Thanks awfully!
