right i had a problem with the water not getting very hot when the heating is on.
i check the pump diverter valve and the tank and rad stats etc all eorking ok.
i changed the thermo stat in the boiler on the pipe and checked the overheat on, so they are ok.
borrowed a pcb from my mate who works at a heating shop and still no difference.
but what i have noticed now is that the boiler kicks up for about 20 mins untill warm then thye burner stops, the fan keeps going and the fan, boiler and pilot lights are on, but when i look through the glass window bit i cant see a pilot only the spark which lights it which just keeps going!
is this normal and the boiler ain't got enough go to warm up 5 single rad and the water?
many thanks
ash
many thanks
ash
