Seen several related posts to this but not my specific problem.
Tripped the ring main RCD last night - after resetting, couldn't operate the boiler for HW/CH. Eventually traced the problem to the circulating pump (won't operate). Tested all the feeds into/out of the controller and boiler and all OK except the feed for the pump. There is no power getting to the pump. Disconnected the pump wiring and now controlling it manually with a plug and the boiler is working just fine (so long as I remember to turn on the pump before turning on the boiler).
I think that there is a fuse on the PCB which may have blown (and which probably tripped the RCD in the first place) but before I go and strip the unit down, can somebody confirm this for me.
Wayne
Wayne
