Baxi Solo 2 PF
Status
Not open for further replies.
5 Jul 2011
Yorkshire
Can anyone help?
I have a baxi solo 2 boiler that is causing me some grief, when you go to fire the boiler up, all you get is the boiler on & the fan on but does not go any further, but a tap on the side off the boiler and it fires up no problem, so I have had the front off and tapped everything. When i tapped the air pressure switch it fires up fine. It only goes into fire sequence when i tap the air pressure switch. I have only just had this air pressure switch fitted any ideas it seems faulty to me or does anyone know of a common fault?
YOU have defiled the sanctuary of your boilers combustion chamber by removing the two quick release fasteners.You are not one of God's chosen ones.
You will burn in your own Hell for all eternity!! :lol: :lol:
Fire in the hole!!
Who fitted it (the part). why not just phone him?
Yer probably right. He's probably banned from the far north as well.
Status
