Hi all!
My first post on here, so go easy. I'm not a plumber/gas engineer - but I'm not a muppet either!
We have a Solo 2 80 PF that is having problems. Basically, it won't light unless the front is open slightly, at which point it will then fire up and run normally - so it almost seems like an airflow (or lack of) problem.
The fan sounds like it's running as normal, so I don't think it's that. I have noticed on occasions that the spark igniter keeps sparking after the pilot has lit, which possibly indicates a problem with the flame rectification, but I'm not sure if that would have any bearing on the way it will only run if the front is open slightly.
Anyone have any ideas?
