Baxi solo 2..until i get approval for the combustion chamber
31 Oct 2008
Surrey
Hi, I'm a Gas Safe registered engineer and have entered my details into "the combustion chamber" and am waiting approval. In the mean time, I need an urgent response before 12 noon tomorrow (Monday). Just need opinions of people with more experience on this matter.
I have a customer with a Baxi Solo 2 boiler, converted to a pressurised system. They had the property replastered and removed the radiators for this. When they refitted everything, this is what happened: When the heating was turned on, within 2-3 minutes, the pressure gauge on the expansion vessel (EV) would shoot up and the pressure relief valve (PRV) would let by. First port of call was obviously the EV, so I checked it and there was water in the schrouder (can't spell it) valve. Also the PRV had now got crap stuck in it, and was constantly dripping. So I recommended a new EV and PRV.
I installed it today with great difficulty in the kitchen base unit under the boiler and turned the boiler on. I then saw the pressure rise within a few minutes, followed by the PRV letting by, just as before. I then heard a burning noise (Tssshhhhh - that's the best way I can explain it) in the EV and piping and the PRV started to let by again. I touched the feed pipe going from the EV to the heating pipe and it felt almost as hot as a joint that has just been soldered!
So I need to know if anyone has experienced this before. Only thing that comes to mind is that there must be a blockage somewhere so the water isn't moving and thus it's burning up when the boiler fires up. I'm going back tomorow at 1pm and first thing I will do is look for any valves in the flow/return pipes that may have been closed and not re-opened (all radiator valves are open, and there are no TRV's), as well as check the pump speed setting. Second thing I'm thinking (if that doesn't solve it) is that the heat exchanger must be blocked. In which case on a boiler this age I'd usually recommend a new boiler if they want any guarantees on any further works carried out (I know that will spark a debate, but that's my professional opinion, since anything else would be extra cost, which will not guarantee no further problems/leaks,etc).
So after that essay, what I'm asking is....Am I on the right track, or am I missing something? And is there any more advice on the situation, since I'm relatively new to heating repairs?
Thanks for reading (if you managed to get through all of that).
Baz.
Just to cause debate.
So is that the secret mystery of the combustion chamber handshake?
It enables highly trained professionals to discuss matters that must be kept from the DIYer lest the master tradesmen show that they are as unknowledgeable as the rest of the world whilst charging for their wisdom.
:twisted: :twisted: :twisted:
Did you manage to solve this? My first call would be to check for correct sizing of expansion vessel then airvents at the boiler..... I'd sign up for the combustion chamber myself but don't have my numbers as I'm a gas engineer currently seeking work :-(
Thanks mate. But yeh I solved it in the end. The pump was siezed which eventually knackered the expansion vessel. Changed the vessel n freed the pump with a screw driver. Funny thing is the pump n 3port valve were boxed in n plastered over. Lol. I still should have known to find em n check them too on my first visit, but that did play a small role in why I didn't
Sods law lol I know that these components aren't the most attractive to look at but they still need to be accessible, what happened to a good old fashioned removable hatch eh? :?
