Hi. Busy forum here.
I have the following problem and would be grateful for any help.
Im not getting any hot water and the heating is no longer coming on.
All the lights are on on the boiler (apart from the overheat one).
I can hear the pump (by the emersion tank) running smoothly.
There is a Mid-Position valve that seems to be working fine. i.e its switching to 'W' when heating water, 'H' when on the heating and 'M' when doing both.
Its all controlled by a Honey well thermostat (which has three wires (+, - and load) and Honeywell programmer. Which seem to be working, the lights are all coming on.
This next part could be the cause.
A while ago the thermostat broke and I replaced it with 2 wire one, sadly i wired it up wrong as i had not reserched wiring up 3 wires to 2 wires. In doing this i blew a few fuses. I eventually managed to wire it up correct but was never really happy with it (didnt look right) so i got a new one same as the original Honeywell.
It was all running fine with this new thermostat for a 2 weeks, but now im getting the problem mentioned above.
I know the thermostat and programmer cables all end up in a box full of wires.
Thats all i know. Thanks in advance for any help.
