Can i install new digital thermostat system on my old boiler
2 Feb 2010
Lincolnshire
Hi, Can i install a new digital thermostat and programmer on my old Baxi Solo 2 50PF boiler. I currently have a Horstmann Centaur TC1 programmer and a Honeywell 3 wire thermostat. Thanks.
Yes you can. Most new thermostats don't need a neutral connection, so just put the neutral wire in a screw terminal to isolate it.
Not personally, they all seem pretty much the same to me, but check out the functions you require, for example different settings for different days of the week, some have a night set back that allow the heating to be left on overnight but at a lower temperature, most have battery back up so the settings aren't lost in the event of a power cut, some have a holiday function so that the system will start up ready for when you get home. In terms of quality, as with most things you get what you pay for.
I’d recommend a Honeywell ST9100C single channel timeswitch for controlling your hot water and a Honeywell CM907 programmable thermostat for controlling your central heating.
