baxi solo 3 60 pf or WILO problem
11 Feb 2008
Hi Guys,
Hopefully you can help... I think I may have done in my heating system.
I was recently redecorating a room and removed a radiator.
While the radiator was off, then the heating came on, and after a while started making strange noises, so I turned it off again. Even after the heating was turned of though, the WILO continued to make noises for a few hours later (kind of a throbbing sound), so I decided then to turn off the power going to that too.
So i didn't turn on the heating again until after I had put the radiator back on. I noticed then that while I was bleeding the radiator, some water entered the radiator, but it didn't reached the top, so it appears there is no pressure.
When I turn the power back on the WILO (Type:StaRS25/4) now, all that happens is that it makes some noise, and an overheat light is constantly lit on the baxi solo heater, even when the timer is set to off.
Any help would be great, we're freezing here!
Thanks,
Alan
Says it alll!
if you have a SEALED system, look for the filling loop and trop it up to 1 bar (see FAQ)
If it's a gravity fed system (small tank in the loft) check that that has water in it. You may also need to bleed a feed pipe to the HW cylinder.
Thanks ChrisR. It's a sealed system, I'll see can I find that filling loop, hopefully that will sort it. My wife's starting to look at me funny, so i better get it sorted soon!
Cheers,
Alan
Says it alll!
Thx ChrisR, some progress made alright using your help. The system has pressure again and I've bled the rad successfully.
However, unfortunately still no heat. Having restored the pressure I turned the power back on to the WILO pump. It's making a throbbing noise, a bit louder than normal operating noise, and on the BAXI boiler itself the overheat light remains on, while all other lights (Boiler on Fan on Pilot on Burner on) remain off. Any ideas?
Thx,
Al
undo the big screw on the end of pump to bleed it.
to reset boiler turn stat to off, leave for 5secs then turn back on.
OK so, after about 10 mins, to try and get the pilot going, I turned the boiler off and on again and it started... thought I was in, all lights on, overheat off!... but then after about a minute, it stopped and the overheat light came on again. The Wilo pump is now also very hot...almost too hot to touch, so I've turned that off too...
damn...so close
any ideas?
thx,
alan
Sounds as though it's still airlocked, have a look on the heating pipes going to the cylinder & see if there's any vents fitted (usually at the highest point). If you have them vent all the air out & then restart the boiler on hot water only, if that works switch to heating only& then try to shift any air on that side.
God lads... this is great. So close I think now. You were spot on there guys, was still airlocked. All good now with WILO overheating.
Last problem seems to be getting the pilot light on. Boiler light is on, but that's it. I tried turning the Stat on and off but pilot light doesn't seem to want to come on again as it did the last time (see above). Any ideas how I can fix what looks to be the last piece of the puzzle?
Cheers guys,
al
ok... seems to be sorted now guys... that turning off and on did reset it this time and pilot is good to go.
Blown away with how quick and helpful everyone is with responses on this site. Thanks so much for all your help, hopefully i can return the favour by maybe recommending a few pubs in dublin where you can get a good pint of guiness.
Cheers guys,
al
