Hi Guys,
Hopefully you can help... I think I may have done in my heating system.
I was recently redecorating a room and removed a radiator.
While the radiator was off, then the heating came on, and after a while started making strange noises, so I turned it off again. Even after the heating was turned of though, the WILO continued to make noises for a few hours later (kind of a throbbing sound), so I decided then to turn off the power going to that too.
So i didn't turn on the heating again until after I had put the radiator back on. I noticed then that while I was bleeding the radiator, some water entered the radiator, but it didn't reached the top, so it appears there is no pressure.
When I turn the power back on the WILO (Type:StaRS25/4) now, all that happens is that it makes some noise, and an overheat light is constantly lit on the baxi solo heater, even when the timer is set to off.
Any help would be great, we're freezing here!
Thanks,
Alan
Thanks,
Alan
