baxi solo 40 /4 rs
20 Nov 2007
Blackpool
i have changed the thermocouple,injector piolet,the valve control sit,so i would of ruled out the solenoid ?,does any one have any more ideas,dearing in mind i cant find a re set button and my house has been empty for 6 months. :?:
the piolet lights,but when i realise the button 2 go on 2 the main burner the piolet goes out,as if there is no gas feed ?
There is an overheat reset button on the back of the thermostat housing
there is nothing on the back of it i have checked just an empty hole on the left back as you look at it from the front,could this be the problem ? a faulty one,dont now how long its been in,but it says in the manual there is one,do i get a new one of them ?,there is nothing else in there you can change ?.
On gravity systems they where not needed and sometimes people removed them completeY
where your t/couple joins gas valve is there a little blue wire bridging 2 spade connerctors
You need a bridge between them. wire with 2 spade connectors easy to make one
could you send me a reply in detail on how 2 do this and where 2 contact it.your help has been great.hope it works am freezing.
