baxi solo power flue
JR5
25 Sep 2007
Wiltshire
Hi all
Having problems with this particular boiler. Innitially I was getting hot water and no heating, 3 way valve changed. All ok. I had a look at the boiler because the fan decided not to come on, hoses to the pressure switch were off. I put them back on, all ok. Left the property.
Today I received a call from the customer saying he has no hot water but has heating and that the boiler keeps going on.
I,m figuring boiler is not going out due to the fact he has heating.
Whats could be causing the no hot water? Pump or wiring or could it be the boiler.
Motorised valve voltage will need to be checked to determine why boiler is staying on
Recheck your wiring and remember rule 1; NEVER assume anything new that you fit is working correctly :wink:
I would add another!
Never assume that someone else has correctly fitted a new part!
Tony
Thanks guys
I meant to say the customer said the Boiler kept going OUT.
I'm thinking cylinder stat may be goosed or set wrong but I will check my wiring.
Cheers
