Hi
We could really do with some advice with some stuff - we recently purchased an old house which is around 200 years old, the downstairs wet room we are gutting and removing everything except the toilet and hand basin.
The issue is the drain where the water was running, there is a slight smell coming from this and we are wanting to block it up.
Is there such a thing as a cap for the pipe?
My idea is to cap off the pipe then put down some visquine and then concrete over it bringing the area up to the floor level.
Here is a picture.
Any feedback would be great for this.
The other area we need some advice is with old exposed beams.
The house has no insolation or sound proofing between the floors, all the wires and pipes run along the beams and are visible.
We love the look of the beams but understand that we will have to sacrifice several inches to cover up wires/pipes and also add insolation or sound proofing.
The beams are 7 inch in depth and we are looking at using/losing up 3 inches.
The question is do I use kingspan and wooden fixings to hold them in place - I can then screw plasterboard onto the wooden fixings and skim the boards between the beams.
Please could someone help or advise us on options we have, some say use soft board to dampen sound and others say use kingspan to add to insulating. - Can we combine both?
Here are some pics which might help.
There are a lot of other things we might need some help with but I will leave those for another time.
Thanks in advance for any feedback.[/img]
Here is a picture.
