Good Morning.
Firstly i'm extremely inexperienced in this field so apologises for my ignorance.
I'm currently looking into removing and replacing the entire heating system within my house. The house is a 3 storey Terrance: 1x main bathroom, a kitchen-dining room spread over the bottom floor, 2 reception rooms (spread over the mid-floor) 2 bedrooms, utility room and potentially a wet room/bathroom, potentially extending into the loft for a master bedroom en-suite.
I've looked at various heating systems and currently thinking either a regular or system boiler and an unvented heating system, thus removing the overflow tanks from the loft (depending on price we might try to extend up there).
Is this the best system setup to go for? pro's & con's?
Can you run a shower pump off this system?
Is it worth installing a hot water circuit so that hot water is always avail at taps?
I've seen you can install quite a lot of technology in the heating/hot water systems, is it worth it? Any suggestions on what to install?
Any Advice/Help is appreciated...
Thank you for your time
