Beko ASPM341PX - how to remove water dispenser components?
15 Jan 2007
Sussex
We have a Beko ASPM341PX fridge freezer with built in water dispenser. When you push back on the pad/lever (or whatever it is called) it doesn't always work. If you push up on it slightly (on the ridges) then it works. I was trying to remove everything to take a look at the issue and try and repair it.
I was able to remove the front control panel to expose everything behind, however I couldn't figure out how you can get anything else out. It looks as though the section that releases the ice through needs to come out before anything. I removed all screws but couldn't get it to move at all. Has anyone got ideas? I checked inside the door and can't find anything where it may be fixed from the other side.
I expect all of the bottom casing will need to be removed to get to the pad but that seemingly can't come out until the component above it.
I don't want to risk breaking anything.
0ws2KC2rjha-XGYE74mZ1OLH-h-VW4Vw9CLUwuRlF5fTqidJi5k11etJxM6bXXShVQjDNmeflBwkz_pCLKprn8RQ1GqPKWBi0mb3JKT9fedOckuVPSEyNKPHvoYgggCKFDua8wWu5OIsFYV9M_ircO0sr_6fjKpRBPhKVgswCfPTe0ruj1esrV49VHofDX5iFOetrnIdLdbk1HbAFVPwCyIp0_Sl0HRGymPKk4Rcxq-eXoWy--LQMCGV_M36c-pHN9Oe5a87QWD-DzlS-ESqYIZPqPFWFJkKTYBOaPD0NvEn0tYoCy-N1NXsqEMy-49OJlNnZnYT1XnvwHDYZPbxNXySGzZITcgaZXy0lRwNmG6hBSCy7tneZ1UyGPB8-FEWQ83NG4i5O68E8r7vZwU0FSgFh9wf_uLqSEVCbIS4BKAb2uwb09xSJZ7XJgo9WnLYmFEBBnLWCPZYHdb-u7kpKpkpFY7EW_H_y_0q0dAOEPYeYJlz7ogViqj0G1LqLhmRy14GzK7Ywo79gnki-cmqBcwcvBNht9ehvi7st8NcKphADFz_gzHZefpy-qCPex271HJMhNUg9KiQKXc10asgNOX6771z7lyN_y4dU8ZPPoD3Z6tjvNUu-o5hijehSZwXdvT5s2ILzz75smg198CCMcAAk1XoCb0-28Q9KrACTII_Eo-yun-6R2-YtSF2VSa-d4vRWRHpNKhLDBvq5BCAo5x9PB14s0bD2cuKtAcoTwmUigStE9johqhVYs6-HP2ES3Cdj28Gz71GBsR3bUlbY9MScqbWc3RH7FP13fqBCyErZmqX70HrkzfM3EUT8ATLo0CakaNpwDEuVJ4qGpXmxVQe37bO0SGteE2kSMybn4wBfb1NIqwGVdInvp8nVJnniQ-hxDC0lHyBUY4CYkZEFN6Fo0F6Qyf6bO1ufe9q9T3mEw=w1608-h904-no
wQvwGdBhPJLHUqeCWyLQgU2NIUjAWzHDXolt71s1DWYP27g-LYuuZodw4XCJcQ7HJmhn9kUxCgJDL5YKnvCqVmPo6iv7DbHouWxjx2LwMHpUwzH_CsdFaablQ0-1oyL1pQEglNlRrts6ywOjKcnouz01U9KPqjK9FqOY0wlskhS8XM7oPJU3y0Zmwqd34_kz8A8sOScbz73p-XUIlgdnEX4fmFm2Cfxw-oMM-3zrBgKRtezkl87nSf9cuP-tr8hVRCfilhPSGv9rIUfP7vXp9EEjRkk3u3dqV3VRFRPOfOLwciK_myIVDbWa4GFpmOpmgdxMDDLnK7LuVx75FA3yOpQVj41HwflDgwUUr2olwesghyhlTSb_1LYsMrdWP4k00nqRAMAB-nkHQpYPmkHza8Cm88GMOF6QU24Es0MI6Xxsze6pak0WdtFekyi6QUBpMa4JoQv6OHxHfFts_lM2uLzlspCGOK2tnHYC8hW6yA4DKt5LpbzwnHdhc4l2f8QC790adA8jzg7_MQFM4mJ_TVeYBmMROJWh-s6ceNxU3Vyj2RxjsUe3s_ZcmKNcR4H6aqGulRqwB6RM8vVasYVAj3mFSHFsuaAgEZJcqDM-gKlTq2g1s5s_7G1CT8YBjzPEMGusVJxF-zbw7f0zHhG4YQZrkP8czkzWCuHXOOgY_pbm6RqcSXx8cMCTQIh3YA7cUgD8guftpbeTZIPwJoKQKB1p7IIvghFZLhckpAIiDXqFlVanxXdN69H10ChZ906Rh-OYan0XDyWdQr9rNN2EO26IYHk81rwdCGZy0ehMrGQaCV-DlvomlxCXqckOrsFXvqVUq6xjQDkfVtR7ZjhLJdotr24j5m2oSpZzhnHoY2JrS13fOn6tluezYgAJ3J8LE97gGh3bkktOyYsUn7xY9L_ONJk8cqsfazVdOpTN0RgNBg=w509-h905-no
