beko TZDA524FS making a very loud noise
2 Nov 2012
Norfolk
i accidently left the freezer door open just slightly before going to work my nightshift.
when i returned 14 hours later my freezer was going nuts and had defrosted half my food. i unplugged it and then re-plugged it and allowed for it to get to the correct temp of -19 degrees but its making a very loud buzzing noise and i cant work out why
any ideas ????
fan iced over???
defrost for 24 hours and try again ??
place your frozen in quilts on the floor and cover with further quilts and or blankets
that was a quick response it is a frost free freezer though so i wont be able to defrost it will i ?
they should be defrosted 2 times a year as the internal channels can ice up
look at the instruction manual for conformation :wink:
ok says auto defrost so----
empty it as i said abouve hot water in bowls at several points inside change every hour or so as they cool after about 12 hours you may be lucky
