bending 10mm pipe
5 Sep 2007
Can anyone recommend a good way of bending 10mm pipe? I only need to bend it through 90 deg. Are mini pipe benders any good?
The bend will be below the point at which it rises to the rad.
many thanks...
If it's a tight bend, then mini benders are better.
If it's a more gradual bend, then spring, or carefully by hand without any tools.
I am using plastic coated so I may see how I get on without tools.
Thanks for the usual fast and reliable advice.
10mm platic coated - Rothenburger make a 12mm slide for their ( and any other ) 15mm bender :idea:
many thanks. Have used a mini bender and it worked great after bit of practice. :D
