bending copper pipes
20 Apr 2014
for a 15mm pipe using a bending spring, what is that maximum that a pipe can be bent to?
Bending springs are not ideal for the job, you need to overbend by about 10-20 degrees and then bend back just to be able to remove the spring and then you will have a job on your hands, much better to get the proper tool and there not that expensive if you are going to be doing a fair bit of plumbing.
Try Screwfix, they are about £45 and they do 15 and 22mm pipe
[Edited by Jimmy on 05-01-2003 at 19:56 PM GMT]
