    Dismiss Notice
Bending wood cladding - thoughts please
Discussion in 'Wood / Woodwork / Carpentry' started by Pickup, 25 Apr 2017.
  1. Pickup
    Pickup
    28 Oct 2009
    145
    Thanks Received:
    6
    Aberdeen
    Country:
    Designing a shed / potting shed / summer house and the client (my wife :) ) would like a curved wall on one side. The curve will be fairly uniform along the length (about 10' (3m)) of the shed and the offset from the ends of the boards will be about 8-12" (20-30 cm)
    We haven't decided on a material yet.
    Most of the info I've found so far relates to bending quite sharp curves in short pieces of wood.
    Does anyone know if pre-cut profiled cladding will be flexible enough if soaked (hot water?) or steamed or should I be thinking about sourcing some green timber (variety?)?
    ANY constructive (no pun intended) comments appreciated.
  2. Sponsored Links
  3. Chud
    Chud
    6 Dec 2006
    737
    Thanks Received:
    60
    Dorset
    Country:
    Unless I'm misunderstanding your post I don't think bending the ends of a cladding strip 1ft relative to the middle over a 10 foot length will need any steam or water unless the cladding is pretty thick..? Most cladding I can think of would deflect more than this from gravity if you picked up a plank in the middle.
    • Thanks Thanks x 1
  4. Tigercubrider
    Tigercubrider
    22 Jul 2016
    3,923
    Thanks Received:
    620
    Country:
    never done it but from watching tv and chatting to a guy…..
    a bit of plastic pipe to use as a steamer, lagged with rags, and a wallpaper steamer as the heat source.
    if the curve is uniform then making a jig to insert the wood while it cooled down might help
    • Thanks Thanks x 1
  5. bobsuerita
    bobsuerita
    7 Feb 2017
    320
    Thanks Received:
    58
    Country:
  6. Sponsored Links
  7. JobAndKnock
    JobAndKnock
    30 Sep 2011
    5,044
    Thanks Received:
    1,094
    Lancashire
    Country:
    Most softwoods up to about 1in can simply be bent round a framework and nailed in place (ring nails preferred). No need to steam bend at all on 1ft in 10
    feet.
    • Thanks Thanks x 1
  8. foxhole
    foxhole
    14 Mar 2006
    16,953
    Thanks Received:
    1,929
    Kent
    Country:
    Use ribbed mdf instead, designed to bend
  9. Pickup
    Pickup
    28 Oct 2009
    145
    Thanks Received:
    6
    Aberdeen
    Country:
    MDF isn't good in the wet tho'
  10. foxhole
    foxhole
    14 Mar 2006
    16,953
    Thanks Received:
    1,929
    Kent
    Country:
    Assumed you meant on the inside?
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
