im installing a switched out door light to the rear of my property.
will be spuring off from a nicely located 13amp double socket located on a ring.
will be installing a 3amp FCU in close proximity to the original socket then will be heading through the cavity wall to the great outdoors where it will pass through an IP54 single gang switch onwards to a IP54 halogen floodlight...
the cable i have in mind is
SWA Armoured Cable 1.5mm 6943X 3core.. from the TLC site...
is this sufficent for the job or does any body have any other better cables
