Hi all, have to fireproof a catnic and the drawing is asking for 15mm plasterboard or gyprock ten, would the 15mm plasterboard be standard board or a fire board, in our house thanks for your time!
Gyproc TEN is just a dense wallboard, (more dense than Fireline as it happens) 10kg/m2 hence the name. And 12.5mm of TEN achieves the same fire rating as 12.5mm Fireline.
