Best fixings for door jambs?
8 Jun 2022
I'm fitting a pre-made frame for a set of folding doors and wondering what to fix the jambs and header with. The kit has come with direct frame fixings around 6.5x90 which would be fine going into masonry, but I'll be fixing into stud, so wondered if those are the right thing to use? I also have some Reisser cutters 5x90 - would those be better to use fix into the wood?
Reisser or Spax should be fine, just fix into all available studs to maximise security
8 screws per jamb should do it, in pairs, 2 - 100mm from the top, 2 - 100mm from the bottom, divide the gap by 3 to get positions for the other two pairs. A couple in the head for alignment. Oh yeh, buy a countersink, countersunk holes are easier to fill.
