- Joined
- 5 Nov 2010
- Messages
- 409
- Reaction score
- 3
- Country
I agreed to help my boss's friend (pressure's on) to hang thirteen (oh dear, bad sign) pictures in a new apartment that she'll be moving in.
After tapping the walls, most of them sound very hollow so I'm assuming they're normal cavity boards. The ones on the outer walls don't sound as hollow but they don't sound solid either like a brick wall would so I'm uncertain what to use.
If it was my flat then I'd just drill a hole and see what happens.
If it helps, her flat is in one of the tall expensive skyscraper-type buildings in Canary Wharf so I'm assuming it's a steel structure without bricks or stone. I attach a photo showing the outer wall with the balcony door.
The question is what fixings is best to hang pictures for these sort of walls including the cavity ones? The pictures are various sizes and already have wire attached to them. Those sticky velco-type fixings won't work on her frames.
I normally use spring toggles especially for any heavier ones but worried that she might be shocked because of the size of hole you need to drill for these. I'd also feel embarrassed if it turns out I can use simpler ones. How about those plastic plasterboard plugs that you screw in? What's the norm nowadays as there seems to be so many to choose from.
Thanks very much.
Thanks very much.
