Best glass scraper I have ever owned- OLFA
16 Jun 2006
London
When I first started decorating, I used the cheaper paint/glass scrapers that accept Stanley blades.
I was never particularly happy with them.
In time my go to became the Olfa BTC1
Rather than just a glass scraper, I used it to cut away silicone seals in bathrooms. I was using it this summer on scaffolding. I loosened the nut to remove the safety cover... and the nut fell through the gaps in the scaffold boards and was never seen again.
I went to my local OLFA supplier to buy a new one. Instead I purchased the OLFA GSR-2. It really is a game changer.
The blade is only 0.25mm thick. The blade for the BTC1 is 0.6mm.
I recently used it to remove silicone from anodised aluminium shower trims. Absolutely no scratching whatsoever. I took chisels with me but didn't need to use them.
You may have never heard of OLFA. They are Japanese. The quality of their blades is stunning.
You will pay a premium, but if you are a professional, their products are well worth the money.
Losing blade protector is a problem.
Just vanishes in thin air.. Ha..
I have to use masking tape around the blade now.
I also learnt to carry a wet stone to keep an edge on the scraper blade.
Not my idea but works well.
Saves buying new blades
