I've got some badly fitted pipes under my landing floor, and the floorboards are a bit knackered. I was thinking to replace the floorboards with a few big pieces of plywood (like modern houses), but I want to raise them so they don't push down on the pipes like the current floorboards do (a plumber told me making the pipes lower would not be a trivial job). I'm wondering if I could put several 1mm thick strips of non-compressible material along the joists to raise the level above the pipes, and make sure the plywood lies flat (I might need 3mm on some joists, 1mm on others).
What kind of material would be good for this?
