Currently investigating replacing the existing in line fan for our en suite shower with something a little more powerful, perhaps a centrifugal fan
Trying to get my head around the set up of avoiding using flexible ducting as we've had problem with pooling water and condensation in the past regardless of how tight the ducting has been pulled, to the point where we stopped using the shower altogether
The current location of the fan in the loft is about halfway between the vent above the shower and the exit vent in the soffit with a total run end to end of about 3m
I was looking to use rigid ducting where possible but wasn't sure of what connectors/what type etc I'd need in terms of connecting the spigot above the shower to the fan and then connecting the rigid ducting directly to the fan on the other side
Presumably I'd need to use some flexible ducting to connect the rigid pipe to the exit vent and perhaps elsewhere?
Haven't been able to find a diagram anywhere that might give me a better idea of the set up to visualise it or indeed advice from any of the fan manufacturers as to what the best ducting and connectors are to use in conjunction with their fans
