Best way to fill hole after removing overflow and waste pipe
27 Sep 2011
I have just removed a copper waste pipe and toilet overflow pipe that is no longer needed..
The waste pipe in particular has left a large gap (half a brick wide) and I was curious to know the best way to make good/fill the gap
My wall is of brick/block cavity construction (with no insulation)
My fear is potential bridging of the dpc
Push something into the hole to a depth of 2 inches as a barrier; then fill the 'outside' 2" with expanding foam. Repeat inside and out.
I would want remove the half brick, track down a whole brick and set that in the outside face of the wall - just so it looks cosmetically correct. The inside leaf of the wall can be done with brick, just sand and cement, or foam depending on whether it will be on show or hidden.
