One external wall of a room in my property is constructed from solid stone but also serves as a retaining wall. The room has 2 other external walls which are not retaining walls but are also solid stone. All of the walls have been rendered in what appears to be a cement render, then plastered and painted.
The room is hard to heat, is in a damp area and gets very little direct natural light, especially in winter.
What I'd like to do is strip back the plaster/render, batten the wall out, insulate, board, plaster then paint.
But I don't know what to do about the retaining wall. As solid stone walls are water permeable I presume it is the render that is stopping the water from migrating from the exterior ground level and into the property.
I am not sure what to do, I could try stripping back the render and seeing what's there and seeing if it is damp, but I don't want to make the changes and then only find out its an issue in the depths of winter. I could just leave the retaining wall rendered and just insulate the other two walls. I am open to any other ideas from anyone more qualified!
Any advice on this subject would be greatly appreciated.
