Hello I'm looking to build a retaining wall in my garden using hollow concrete blocks, about 0.7 metres high and then rendering it. What I'm unsure about is how to stop it getting damp and blowing the render. I'm assuming I can put some DPM between the wall and the earth behind but what do I do about moisture from the ground underneath the wall, should I use engineering bricks for the first couple of courses? I've seen quite a few retaining walls rendered all the way down to ground level, does this cause problems with damp rising through the render? Thanks in advance for any advice.
