Ongoing garage conversion but cutting PIR is not my favourite hobby so am wondering if a decent thickness rockwool between these ceiling joists and then say 50mm PIR layer screwed to the underneath would work / keep BC happy. Not just from ease point of view but rockwool might help with sound insulation as well.
Also re moisture - there is an open plan kitchen round the corner, this bit is the dining area. There is / will be permeable membrane at the wall cavities but will I need one for the ceiling bearing in mind the space above is already ventilated at the eaves and will have additional vent bricks installed in that triangular section - requested by BC.
I don't mind fitting PIR in the new timber walls as they are easy neat sections but the ceiling joists aren't so and prob not totally parallel / square.
It's only a 2m x 2.3m area and my sons place so not worried about finding the cheapest option.
Cheers
Cheers
