My Mum and I recently moved into a Chalet Bungalow which was built sometime in the 70's. Long story short, my Mum gets cold really easily and I tend to overheat. She's let me have the upstairs rooms (the original 70's construction and a loft conversion done sometime in the 80's) but as heat rises it gets really hot up there. Even with all the upstairs radiators turned down, in the winter I get too hot. I also want some soundproofing as one of the rooms will be a gaming room but it's directly above my Mum's bedroom so need to help deaden the sound!
So I was thinking of putting some between floor insulation in. Is this a worthwhile effort do you think? One of the rooms is currently empty and will be easy to remove the floorboards, but the other two rooms will be more challenging.
Does anyone have any recommendations as to what I could use, either between floors or, if you think that's a fools errand, perhaps something I could lay on the floor under the carpet that might have some insulating and sound proofing effect?
Thanks in advance!
Ex.
Thanks in advance!
Ex.
