BHp drop
22 Oct 2010
Yorkshire
My wifes car is a VW polo - Car drives fine, then suddenly seems to loose power - like its struggling - then picks up fine again... does this alot..
Any ideas?
It could be a lot of things.
If its a petrol it could be a dodgy coil pack.
If its a diesel it could be a dodgy MAF sensor.
Assuming its a relatively recent VW you could find a dealer or independent specialist to read the fault codes stored in the ECU and tell you if anything is wrong.
Yes fault codes will show you what way to go
Strange - ive driven it n its fine - only when she drives it happens.. anyway ill buy a fault code reader n go from there... cheers
Since last discussion, i've had engine swapped - started fine, ran fine.. jobs a good un...
Went to start it 10 mins later -nothing.. engine turns but thats it.. thought sparks.. they're ok.. coil pack would be next, but after that..any ideas?
WV polo 1.4 8v
Decided to get a replacement engine in.. did this on saturday.
Hooked up - turn ignition. starts great - purrs... ignition timing a little out..so turn it off.. fix issue turn key... engine turns.. no spark..
Do you think this could be amplifier or coil?
