Hello,
I've had help here before so thought i'd give you guys another go!
Back in December my boiler started to behave erractically. I called my usual gas man who said it was the timer and replaced it with a digital timer (SUNVIC Select 107 XLS). It soon became clear to me this timer did not work - heat coming on randomly or not when I had timed it to. I had also lost hot water in my bathroom!
My gas man came back and replaced the timer like for like saying the 1st digitla timer must be faulty. Immediately there was the same issue with the 2nd digital timer.
Apparently he now thinks the digital timer does not work with my boiler and has ordered me a new standard timer - same as the original broken one that's still attached to the boiler.
My questions:
Can anyone tell me if there is a compatibility problem between the SUNVIC Select 107 XLS and Biasi 24S Combi boiler?
Should I accept he is installing the old style original timer again?
Can I have a go at rewiring myself? - i'm relatively handy but don't have a wiring diagram for the digital timer
This same issue has plagued me for nearly 5 months with my boiler man being one who doesnt answer his phone and makes promises to turn up then doesn't! - but then that's a separate issue.
Any help would be greatly appreciated.
thanks,
Cat
My questions:
thanks,
Cat
