I have a Biasi 28s, its around 10 years old & for the most part has been a very good piece of kit.
However its playing me up now & i seek some advice from whom ever can help.
When DHW is called for the boiler fires up & nice hot water is supplied for about 5-10 seconds, it then very quickly reduces temp to nothing more than luke warm even though the burner is still in operation, occasionally the burner will shut off but restart again but not in a regular pattern, it may go off and on once or twice at the first drawing of hot water ... for the most part the burner remains on.
Reading through similar problems on these forums i have changed both membranes & the DHW flow switch .. which have had no effect, when i purchased these items i also got a Temperture sensor/probe but havent fitted it as yet because the removal of the wiring clips to each of the sensors in turn that are already in situ (thus sending a nil temperture back to the pcb) doesnt make any differance either.
The C/H works as it should.
Any advice would be gratefully appreciated.
Best regards Glenn (southampton)
