biasi boiler seperate programer
9 Oct 2010
Essex
i have a biasi combi and it is going in the loft it has a built in programer but i would like a programer in the kitchen how do you wier the new programer in to the new boiler that has a built in programer
No response to date that Terrys ? as I see it you would leave the timeclock on the boiler set at 24 hrs & utilise a programmable room stat , you probably already have a room stat ?? BUT & this is important most if not all ?? Biasi combis have volt free conections from the control board to the room stat !! this means they send voltage out to stat ect they do not like equipment that sends or puts voltage onto the pcb , so you need volt free contacts , you should be able to down load M I' s ect from the biasi website , assume the boiler is a fairly modern one ??
the boiler is not in yet its new im not having a room sat just a programer so i can boost the dhw or the ch when i need to
So you are getting a Biasi than , hope you don't have a problem with there after sales than :wink: £95 deposit to attend an in-warranty fault obviusly refundable if it is a manu fault & not an install fault :wink:
Apparently they do not attend intermittent faults either ?? or so I was told ! Lousey company to deal with in my view/opinion !
Boost your hot water ?? combi ?? are you linking it to a cylinder ??
No room stat ?? lets hope yopu do not need a warranty repair than service agents down here (some) will walk away , that a be your £95 gone ?? maybe , possibly ??
B oost your hot water ?? combi ?? are you linking it to a cylinder ??[ /quote]no i ment if i come home and the water is not hot i just ment i would like to advance the set time of the on period
Its a combi boiler comes on as you open tap ?? or does the boiler have a pre heat facility ?? that you are attempting or wanting to control ??
See above or previuos post about room stat !
The boiler is not in yet, it's new. I'm not having a room sat, just a programmer so I can boost the dhw or the ch when I need to
How will you control the room temperature?
How will the mandatory requirement to have a boiler interlock be met?
PS why start two topics on the same question? :roll:
sorry i ment the heating not the hot water
As D Haisham said you need to have temp interlock on the boiler this will be a requirement in the benchmark log book that comes with the boiler , which all manus will be tightening up on no log book no warranty is the word out ?
trust me in the event of a warranty fault BIasi UK WILL , look for any excuse to walk away ( maybe )
would suggest a programmable room stat although volt free time clocks are available & than use a normal room stat !
What Biasi is it ?? Normal as in non programmable !!!! try a digi stat !
