the boiler is not in yet its new im not having a room sat just a programer so i can boost the dhw or the ch when i need toNo response to date that Terrys ? as I see it you would leave the timeclock on the boiler set at 24 hrs & utilise a programmable room stat , you probably already have a room stat ?? BUT & this is important most if not all ?? Biasi combis have volt free conections from the control board to the room stat !! this means they send voltage out to stat ect they do not like equipment that sends or puts voltage onto the pcb , so you need volt free contacts , you should be able to down load M I' s ect from the biasi website , assume the boiler is a fairly modern one ??
transam";p="1762036 said:So you are getting a Biasi than , hope you don't have a problem with there after sales than£95 deposit to attend an in-warranty fault obviusly refundable if it is a manu fault & not an install fault
Apparently they do not attend intermittent faults either ?? or so I was told ! Lousey company to deal with in my view/opinion !
B oost your hot water ?? combi ?? are you linking it to a cylinder ??[ /quote]no i ment if i come home and the water is not hot i just ment i would like to advance the set time of the on period
How will you control the room temperature?The boiler is not in yet, it's new. I'm not having a room sat, just a programmer so I can boost the dhw or the ch when I need to
sorry i ment the heating not the hot waterIts a combi boiler comes on as you open tap ?? or does the boiler have a pre heat facility ?? that you are attempting or wanting to control ??
See above or previuos post about room stat !
