I think I mat have the answer to this but thought I would check here anyway.
My Garda started leaking from the primary circuit flow switch plunger. Simple fix was to replace the diapram.
All worked fine, no leaks and boiler started well.
However having raplced all the panels the boilder no longer starts. I have again taken it apart and can see no obvious faults or unplugged leads.
Both green lights are flashing and after 30 or so seconds the red light comes on. This, according to the manual indicates a fault ignition sequence device (i have checked the fuse on this board and it is fine). However I only replaced this 18months ago whn the previous one burnt out. This one shows no sign of failure.
On demand (DHW or CH) the fan will start and so will the pump but there is no spark or even any clicking going on from the Ignition sequnce board.
I am about to buy a new ig seq device but thought I would check a few things....
If the ignitor had failed or there was a break in one of the two wires to the igniter would it trip the same error?
Why would it fail, it was find till I re-asembeld the boiler?
When assembling one of the connectors to the igniter came undone, but I pluged it back in, however could than have blown the board.
What gets me is that this is too much of a co-incidence that I fix one fault and another occurs straight away, can't get over the nagging feeling that it is a broken wire from the Ig seq device rather than the board itself.
Any views?
Very many thanks
John
Why would the board fail, [/list][/list]
Any views?
Very many thanks
John
