And I'm easily confused let me tell you. I'll check again later but as I recall whether you draw hot water or the CH is on the two outermost green lights just flash steadily alternately.
Back again - the time gap was unavoidable unfortunately. Right where were we...
Tony, hot water makes the green lights flash alternately side to side, heating makes both of the green lights flash together.
Just an impression - when the burner comes on for heating there seems to be a good strong flame and OK the pump is running, but you can sense the 'power' in the system.
When you run hot water, the noise of the water flowing tends to mask things but although the burner lights, there doesn't seem to be the same power there. Might just be me...
