Biasi m90 24s
14 Nov 2013
Hello all
I have a problem with my biasi boiler,
I tried to wire my new thermostat to boiler but the thing is that when i turn on c.h the first two lights flas on my boiler(thermostat is off) and the furnace is heating anyway. when i turn thermostat on the normal procedure happens the first and third light are flashing.
I also tried the boiler without thermostat: with the m link between 1-3 in the boiler is working correctly. if i remowe the link again the first two lights green and red are flashing together and the boiler doesnt shut off.
any ideas?
First two lights flashing indicate operation of the frost stat circuit!
Have you mistakenly applied mains voltage to any of those 1-3 connections?
Or applied a mains neutral to any of them?
What model is your stat?
Tony
actualy I may have accidently put neutral on thermo when wiring it
Applying any external connection to either of those two terminals may have damaged the PCB in the boiler.
An expensive DIY job there. Better to have a professional do it for you!
They must be strictly a two wire volt free circuit.
Tony
As i see you are a professional, is it possible to fix pcb or should I just order a new one?
I don't know if you have damaged the PCB.
As an electronics engineer I can repair PCBs if I wanted to but most would replace a damaged one with a new one!
Tony
Those biasi pcb's are too expensive.
There is a company in wembley that repairs pcb's and gives a years warranty.
You send them the faulty one and they send you a reconditioned one.
