Biasi M96.28SM/C - Pilot Light not igniting.
19 Dec 2016
Hi all,
I live in a static home, and this is my boiler. The gas ran out yesterday and since putting in a new bottle, I have been unable to get the pilot light to ignite.
When I make a request for heat, a fan kicks in and the igniter starts sparking, but it then stops and the 3 lights are the bottom go from Green Flashing/Clear/Green Flashing to Green Flashing/Block Red/Green Flashing and the Pilot Light light goes red.
Any advice?
could be variety of things would be better to get someone in to keep cost down
whats a bottle ?
a cylinder.
I can't see a picture of the boiler, or its make and model.
Do you have another gas appliance in your static home a Hob or fire ? are they working Ok ?
Your boiler is actually A Biasi Riva Compact HE and it does not have a pilot light
Hob is working fine, as is the oven. It's just the boiler not kicking in when I request heat for the hot water and/or central heating.
what you call the pilot light light is the flame lockout neon , when you change the bottle some air can get in the line so you have to press the reset button next to it a few times to purge the air out, if it keeps locking out after a fair few tries you will need an engineer but it should come through eventually
  • Thanks
Reactions: DH6
That seems to have been the problem, it's now turning on if I press the ignition button, some residual air in the lines I guess.
Many thanks :)
