biasi prisma 24se constant cycling
15 Sep 2005
Essex
Hi all,
my biasi 24se constantly cycles in either dhw or c/h modes (also when both are on)
Any ideas please?
sorry, forgot to say,
it gets to 60c after first couple of cycles but then cuts out and re-fires every 3secs or so.
MOD
please use the edit button
We can be fairly safe to say it shouldn't DO that, so you need a boiler engineer. Unlikely to be anything that can be fixed by diy. :cry:
Thanks for that but I was hoping to get some advice on what it could be. Dont intend to get involved with any gas areas of the boiler but if its anything else I am keen to learn. Have changed various parts myself in the past and had no problems with those parts. Obvoiusly this problem could be linked but it was only a temp probe and various parts for diverter valve, including dhw pressure switch which was rusty and leaking. :rolleyes:
Well it could be a rogue bit of fluff somewhere critical (that you shouldn't go) or it could need a new pcb or gas valve! Sorry, it isn't possible to make any guesses!
