I have just come back from holiday and tried to switch on the central heating on my boiler. Currently I have hot water. When I moved into the flat a few months ago, I used the central heating for a few days as well so I know this works.
The scenario is:
Water pressure at 2.2 on the gauge
Green light flashing approx every 1 second
Timer set to 'auto' and is showing as 'on'
If i switch it off at the mains then switch it on again, it initially fires up for about 6 seconds and then goes out again.
The strange thing is that if I run the hot water tap you can here the boiler firing up and I get hot water, so maybe this is down to user error.
I have read the manual and tried everything, so any help would be appreciated,
thanks
M
The scenario is:
thanks
M
