- Joined
- 30 Jan 2021
- Messages
- 2
- Reaction score
- 0
- Country
Hi, I have a problem with biasi boiler DHW supply but only to the shower. Kitchen tap and basin is running hot but shower is barely warm. I have called a plumber who changed thermostatic valve in the shower but it didn't change anything, he then took the shower off and run the hot water directly from the pipe in the wall and that how it comes from the boiler- barely warm. When he reduced the flow from the boiler with isolating valve or blue valve under the boiler water temperature temporarily goes up and down again. He changed 2 temperature probes but nothing has changed. 3 fault lights (green,red,green) flashing together 1sec on 1sec off and there's no fault code like that in manual. After half a day looking for problem he said I'll need a new boiler as this one is old anyway and probably not worth repairing, but apart from that shower problem boiler is working fine. Hopefully someone can advise me if replacement is the only option or there is something silly he have missed? Thanks in advance.
