THe boiler is a biasi 24s.
Yesterday it was working intermitently. The heating would be on for about an hour and then it would go off. Checked the boiler and had to reset the red lockout switch. Fan seemed to be a little noisier than usual. It did that for a few more times.
Today it wont light at all on hot water or heating. I have taken the cover off and can see the microswitches moving on the diverter valve. I know some of you may shout but i also removed the inner cover. The fan turns for a few secs (as if trying to get to speed) and then stops. A few secs after it locksout. Is there a way of testing if the fan /fan coil is broken and could it be anything else that would cause the fan to stop turning
