Bib taps with 45 degree pipe entry?
9 Aug 2011
Essex
I have a customer who wants to replace two bib taps that have a 45° pipe spigot over a butler sink. They screw directly into 1/2 BSP 90° unions on surface mounted pipe work that is 75% buried in tiles so not easy to re-plumb without making a real mess.
Are 45° curved Bib tap extension mounts available to use normal 90° back or bottom spigots? Are bib taps with a 45° pipe spigot still available anywhere (not according to Google)? Any clues, ideas or suggestions welcomed! :?
Is this what you mean by 54 degree: (Whoops, should be 45 degrees! :oops: )
Most cheap ones are of that design and most local merchants will have them.
Do you want them in brass or chrome finish?
Right angle - but it is an outside tap. I need indoor chrome taps.
Thanks for the nod on BES but they only have garden taps also.
We get the cheap brass ones chromed regularly for customers.
They don't end up shiney, just silvery-coloured.
You gets what you pays for.
