Hi everyone this is my first post. My boiler's HW is working fine with the Horstmann C27 2ch; 3 prog. But the CH only comes on with the first 2 of the progs. The 3rd HW prog calls 1 hour before the 3rd CH prog and that is where the problem is. The CH just will not cut in and fire up the boiler even though the C27 Programmer light is activated. After about 15mins it finally kicks in but before that you can here a low pulsing buzzing noise coming from the 3 way valve's actuator. The Hot water is very hot and cyl stat set @ 45-50 deg C.
Any ideas apart from changing every piece of this system?
for info: Grant 70/90 Euroflame, B.House model: Horstmann C27 prog/timer, Horstmann Z322XL 3 way valve; Honeywell L641 cyl stat. DAB pump and rads with TRV's.
