biro on lino
I'd do a bit better if I knew what "Biro" is. (Haven't got a clue, actually.)
Did the "Biro" stain the linoleum so that you can't wipe the Biro off with a damp sponge?
Do you expect that bleach straight out of the jug would remove the Biro?
As previously stilted ... Biro is a common term for a ballpoint pen
Someone at Wikipedia said:
Ladislao "Laszlo" Josef Biro (Bíró László József, September 29, 1899 - November 24, 1985) is considered the inventor of the modern ballpoint pen.
Biro was born in Budapest, Hungary in 1899. In 1938, while working as a journalist, he noticed that the ink used in newspaper printing dried quickly, leaving the paper dry and smudge-free. He tried using the same ink in a fountain pen but found that it would not flow into the nib, as it was too viscous. Working with his brother Georg, a chemist, he developed a new tip consisting of a ball that was free to turn in a socket, and as it turned it would pick up ink from a cartridge and then roll to deposit it on the paper. Biro patented the invention in Paris in 1938, after fleeing anti-Jewish laws in Hungary.
In 1943 the brothers moved to Argentina and on June 10 filed another patent, and formed Biro Pens of Argentina (in fact, in Argentina the ball pen is known as birome). This new design was licensed by the British, who produced ballpoint pens for Royal Air Force aircrew, who found they worked much better than fountain pens at high altitude.
Ballpoint pens are still widely referred to as a biro in many countries, notably several European countries, Australia and New Zealand. Argentina's Inventor's Day is celebrated on Biro's birthday, September 29.
:wink:
And here I thought Biro was something you drank. (Musta been thinking "beer-o")
Inks will often have an alcohol base so they dry quickly, and that's why hair spray (which is also alcohol based so it dries quickly) will often remove ink from clothing. Try spraying it with hair spray and wiping it off. If that doesn't work, I'd try some other solvents like white spirits (paint thinner) and isopropyl alcohol if you have any handy.
Nail polish remover often consists mostly of just acetone in a bottle, and acetone would also be worth a try. I've found that acetone causes some of the linoleums I have in my bathrooms to swell up, but doesn't seem to affect others at all. Those that swell up seem to shrink back down again and don't show any permanent damage from the acetone that I can see. So, if the hair spray and white spirits don't take it off, try wiping the mark off with a bit of toilet paper dampened with nail polish remover. Maybe test in an inconspicuous spot, first, tho.
