Hi guys,
I'm thinking of doing the plumbing for the radiators in my 2 storey extension but need a bit of advice.
I intend to run the main supply and return under the screed in 22mm and feed off to the rads (4 in total) with 15mm. To avoid running the main supply and return right around the building, some of the rad feeds will be quite long (4m ish). Is this a problem?
Thanks in advance.
Thanks in advance.
